Yes it was. Damn. I guess i need to do more research and fins a proper box.Since you did not identify your "simple adapter", I will assume it is the cheap passive kind. Those require that you set your computer to 640 x 480 (NTSC resolution) Cheap converters can't convert horizontal and vertical scan rates, they can only convert the signal voltages.
