Vertical lines in Vegas Pro 9e
spamrakuen
Look at this sample pic;
Can you see them?
Here is a crop;
I was able to workaround it using 32-bit instead of 8-bit; but it eats a lot of memory and it's sloooooow.
Any idea? :violin:
Thanks.
pd. It's a MTS file (AVCHD) created with a Panasonic GH1 rendered with Vegas. Original file does not have these lines.
I could not see them unless i boosted the contrast.
yep, i´ve been seeing those in HDV files from a long time (vegas 7 maybe?). I thought it had to do with 1440x1080 being enlarged to 1080 but i also saw it in some 1920 files i think.
Then, did you found a way to solve this? Or you have learned to live with them in peace and harmony? :D
It's either macroblocking or the color sampling; probably the latter.
What exactly did you do to render this?
i could never fix it. And it made no sense beacuse the original files looked fine. I can´t remember the details but try converting 1 file to qt uncompressed for example and throw it in the timeline to see if it still looks bad.
