Velocy curve question
Why does the velocity curve start playing the clip in REVERSE when you pull it down from it's mid point starting position?
When you slide UP it SPEEDS up the clip.
You'd think then that if you slide DOWN it woudl slow down the clip. Instead, it is playing it backwards. Is this a raylight related bug??
It sounds like you are pulling it down too far. It show go from 100% to 0% and then start to go negative, which means it will play reversed.
You can see the velocity value as you drag the curve down. Holding Ctrl at the same time as dragging gives you more control - i.e. it moves in finer steps.
You can also right-click on a control point and use "set to" to make the velocity any numerical value you want (within limits of course).
tHANK YOU, I will try above tonight and see how it goes.
