Hi i would just like to know if you are able to sync the velocity envelope with the sound on the clip. For example, if you put the video clip in slow motion is it possible to put the sound clip in slow motion at the same speed?
I don't believe there's a way to do it with the velocity envelope. However, if you go into the clip properties and adjust the playback rate manually, it'll slow the sound with the clip. Or, ctrl-click and drag the edge of the clip out.
