Viscount Omega
Carbonite Member
Hi, I'm testing out a Blu-ray render for DVD Architect 6.0. I have a 90 minute video file I rendered using the Vegas template:
Blu-ray 1920x1080-24p, 25mbps stream. It created a mpeg2 file with extension .m2t
I used default settings except:
Frame rate 23.976 (same as I shot it in)
High quality video=31
Variable bit rate default (30, 25 avg, 20mbps)
I checked "two pass" setting
rendering quality=best
I unchecked the boxes for creating the audio stream so I have none.
The resulting video file is 19 GB. (It took 26.5 hours to render. LOL.)
The blank disc I have is 25GB capable.
When I load the file into DVD Architect for Blu-ray creation, then prepare, it says the file will be compressed. Not re-compressed, mind you. Don't I want it to not be compressed? If so, what am I doing wrong?
If I hit "fit to disc" under "optimize" it still only takes up 63% of the disc.
