Greetings,
1. I am using M2(35mm) adapter and as you would expect it, the images come in inverted into Vegas when I import them. I then do a pan/crop event and flip the "F" 180 degrees. Of couse if I have 10 clips I do this 10 times. Is this the best way to flip the image?
2. When i apply any effect do I have to apply it clip by clip? in other words can I apply an effect to the entire timeline?
3. and finally, I want to do a track motion so that I could play two clips simeltaneous (i.e split screen scenario). I normally create two video tracks and track motion on both the clips and adjust the frames. This works fine but what it seem to be doing is tracking motion for all the clips on the timeline. I want this effect applied only to a specific clip. of course one way of doing this is to place only the clips that i want to do track motion on first and then render out a new clip and then include the new clip on to the main timeline.
Would appreciate any help. As always this site is top notch.
cheers,
-Kris
cheers,
-Kris
