macgregor
I´ve spent +4 hours dealing with the following issue: Sony Vegas does not use more than 8bits from QT files. I´m not sure this is a QT issue or a Vegas issue but in any case, it's bad for us.
After noticing how prores files looked really bad in Vegas (compression artifacts, banding...), I started playing with different formats in the timeline and applying contrast to see where the gradients break.
These is what I've found out so far:
- QT prores files show artifacts and banding in Vegas (8bit or 32b don´t affect this issue).
- Opening that same file in AE CS6 shows no problem. It looks perfect.
- Converting the prores file in AE to a high quality codec like blackmagic 10bit RGB as AVI and then importing it in Vegas --> shows no issues. It looks perfect.
- Converting the same prores file in AE to the same blackmagic 10bit RGB codec as MOV, and then importing that file in Vegas --> shows compression artifacts and color banding.
Then I tried a couple more formats and the results are consistent. QT files in Vegas look like crap even when the format and original source were 10bits.
