Vegas Project Properties Template Question
bigox
This should probably be a no brainer, but I wanted to check.
I'm used to editing DVX footage. For the way I shot with the DVX, my template properties for Vegas for the DVX was always: NTSC DV 24p Widescreen (720x480, 23.976 fps)
Now that I'm shooting with the HVX200A, I'm not entirely sure which template I should be using. I shoot in 720 24PN mode. I'm assuming the best template to use would be:
HDV 720-24p (1280x720, 23.976 fps)
Does that seem correct?
In the future, if you're uncertain, in the properties section you can select a file for Vegas to analyse and pick the best template for you.
vegas 12 ask you do you want to match the properties when you add footage to the timeline.
