macgregor
I´ve been experiencing a problem with Vegas 6 and 7 for the last year. Everytime i use slow motion from an interlaced footage, the rendered video results in a flickering video that cannot be used. Sometimes it is not very obvious (fro example in Similo), but sometimes it is a huge problem:
www.macgregor.autoecstasy.com/flicker_vegas_problem.mov
Check this file. That is unaceptable. I cannot work with this.
It does not matter if the video source is HDV or DV. Same problem appears. Upper or lower field does not affect this. I have tried everything without success.
I am working in PAL which means 50i. But i have heard the same problem also applies to 60i (can anyone confirm this?).
Anyone found a solution? Is it a Vegas bug unsolved?
