i need som help and info on vegas. iam running vegas 6. the project setting iam using is:
templet- HDV 720-25p
w1280
h720
filed order NONE
Pixel aspect ratio: 1,0000 square
frame rate 25PAL
Deinterlace methode: Blend fields.
then i put a bland white box on the timeline. then i render on this setting:
output type: DVD
w720
h576
frame rate 25
aspect ratio: 16:9 Display
field order Progressive only
video format PAL
when i render this i am getting black line i both sides left and right. it happen also when i put the jvc hd pro files in the vegas. is there anything iam doing worng ? shouldnt i get full WIDE white box ?? no cap in left and right side?.. please help me. urgent.
rajan
if u have msn contact me on : rajan_cs@msn.com
w1280
h720
filed order NONE
frame rate 25PAL
output type: DVD
w720
h576
frame rate 25
video format PAL
rajan
