Hi- I'm hoping someone can give me advice or suggestions. I'm working on a project in Sony Vegas Platinum 8.0 and have the demo for Pro 8.0. I need to make a short video from MXF files originally from an HVX200, shot in 720 24pN. I am using Raylight as the converter of these files. All is great. Now, I need to render and use DVD Architect to make the DVD. This will be used for broadcast TV purposes. For rendering, the Raylight tutorial says: Click on File->Render and select Main Concept MPEG-2 file 23.976 fps with 3:2 pulldown, widescreen, if you shot and edited at 24P. The audio should be exported to the Dolby Digital AC-3 format. In the Pro 8.0 version the closest option for "Main Concept MPEG 2" is a template reading "DVD Architect 24p Widescreen video stream", and the closest option in Platinum 8.0 is "Main Concept MPEG-2" with the template being "DVD Architect NTSC Widescreen video stream"...I believe. However, this setting has no audio. I go into CUSTOM and click to enable audio stream. (I guess this is what I'm supposed to do?) The quality seems OK. But, are there any suggestions for rendering, settings, templates- should I be rendering to an AVI for better quality? Since what was filmed is 24pN, should I even be choosing the template for 24p? (In Platinum, there is only a general "DVD Architect NTSC Widescreen video stream" option but it keeps trying to default to HDV 720 25p when I go to enable audio.) This will be eventually be transferred to a DigiBeta for use on TV, so I need the best possible quality, and it's only a few minutes long so I can use the least compressed (or no compression) settings.
Also- for the project I am working on, is there really any difference between the Platinum and the Pro? Is it worth the upgrade? I'm new both to HD and Vegas.
Any suggestions would be incredibly appreciated.
Thanks so much-Ken
Thanks so much-Ken
