Vegas Duplicating Frames
darmanb
Please help!
I am working on a 3 minute 24P project in Vegas 5.
After rendering to an uncompressed avi file, I notice that on some parts of rendered (new) clip a lot of frames have been duplicated (for example: 2 identical frames are in sequence, then next 3 frames are good then 2 frames are the same etc). On these parts of the clip, footage looks unsmooth and not good.
What am I doing wrong?
In rendering window I set it to: avi, uncompressed, progressive, best quality, NTSC 24P.
I thought this had something to do with keyframe interpolation in pan-crop window (I have a lot of keyframe animation in this project) - so I set the smoothnes value to "0" instead of "1" (by default).
Nothing changed!!!
I also tried turning off the "interleave" function in rendering window.
No change also!!!
I would really appreciate your help with this one.
My project properties are NTSC 24P (23,976 IVTC) with Pulldown Removal "on". I finish my transitions, effects etc., then "render as" - windows avi, uncompressed, best, size: ntsc dv, field order "none - progressive", codec - uncompressed.
When I import uncompressed avi file into this project, and double check with scrolling frame by frame on a timeline - it has duplicate frames.
For some of the video events, yes I did.
But I also went in their properties/switches and changed sampling to "disable resample".
