Check your ram and see how it is being used. Do you have a lot of programs running in the background? Turn off any unnecessary program. Otherwise run a memtest88 and see if your ram is going bad. I had to replace my ram recently and found it to be the problem. Also check to make sure your running under DMA mode for your hard drive. It is under device manager in your system folder and look under IDE ATA. Then look under advanced settings.
