BennisHahn said:Core duo 1.6 Dell Insperon. It flies with DV editing (haven't done any HD). No firewire problems at all. I got the 7,200rpm hard disk option and the thing runs very smooth.
Editing on a 15.1 wide screen is fine, just make sure you get the highest resolution you can (1680x1050). I pipe mine out to a Dell 20.1 wide screen monitor and it is a dream.
I would format your HD when you get it and install a fresh version of windows, as Dell bogs the thing down with so many little user programs, instant messaging, etc...
brianluce said:Hi, is that the e1505 model?
Mark Harris said:I have the E1705 and just edited our 720 HD dramafest entry on it with no issues.
Also used it to cap a lot of the footage via HDRack with no issues. It made a decent monitor on set as well.
I would agree about doing a fresh install when you get it. I did NOT do that on this machine, and there is a lot of crap in there. There is some piece of crap in there called PCMService, which has a massive memory leak...urgh...
One odd thing, and I have not researched this at all, but when rendering and even exporting from a 53 gig master to a QT h264, my older P4 editing machine was a LOT faster than the core duo E1705 at the same tasks. Again, I have no idea why, but it was weird...
greeches said:no, you want max rez so you can fit as much "stuff" on the screen. You'll want to see your preview window, timeline, start menu... etc.... The rez will still display your other footage properly...
brianluce said:Thanks for the info,
Do you have the Hi rez screen or the 1280x800?
Where you able to focus with dv rack?
Mark Harris said:I got the super-duper screen, whichever one is the most expensive add-on. Yeah, it works for focusing fine.
M
Mark,Mark Harris said:There is some piece of crap in there called PCMService, which has a massive memory leak...urgh...
