Vegas 9e slow motion & blu-ray dvd
rick1000
I am shooting some football games with a Sony NX5u and processing Vegas. I like to slow down movement by right clicking on the right of a clip and dragging it and the audio track, increasing the track lenght by about 20 percent. I have many short clips to process in this fashion; any way to select all clips and extend the entire group with one operation?
Also, I'd sure like to have difinitive set of instructions to cause Vegas and dvd architect write a blu-ray HD video with menu control to standard dvd. Something Pinnacle can perform. I can play blu-ray on dvd with a PS3 but only as a data disk playing a file from the streams directory.
Thanks in advance for your thoughts....
Rick
You can drag one, copy it, select all the others, right-click, and choose "paste event attributes."
This will paste everything, including FX and crops, so do it early.
As for the second question -- not sure what you're asking. Do you want a standard DVD playable in standard DVD players?
Blu-ray on standard dvd
Thanks for the tip on dragging groups. Regarding the second question:
I would like to use Vegas and DVD Architect to burm blu-ray format (or any HD format) onto a standard dvd tp play with a Sony PS3, and other Blu Ray Players
Well....
1. BluRay is the ONLY HD commercial optical format.
2. Playing in a PS3 will work fine
3. Playing in other BluRay players probably won't work fine.
Nothing special need be done in DVDA. Set up a BluRay project, do everything just like you were going to write to a BluRay. But instead of putting a BluRay disk in the recorder, put a DVD in there instead.
Also, mind the length. If you try to put more than 10-15 minutes on there, it's not going to look so hot.
