V-mount - brand new batteries problem
casino83
I finally got my batteries and charger for my new (used) PDW-F330.
But there seem to be some problems...
The charger has a DC-output and when I connect my camera to it - everything works fine. Feels good to actually know that the camera works!
The batteries are from Vect: ET-130S V- type Li-ion battery pack
Link: ET-130S V- type Li-ion battery pack | china ET-130S V- type Li-ion battery pack manufacturer
14,8V, 8x8Ah, 130Wh
It's not exactly that battery, mine has a LCD-display where I can read cycles, voltage and remaining time. I have two batteries.
THE PROBLEM:
1. One of the brand new batteries doesn't seem to be charged at all. Both the LCD on the charger and on the battery says about 15% charge - even after about 10 hours in the charger.
On the other hand - the other battery seemed to be almost fully charged from the beginning. Because of that i rather quickly got up to 98% on that battery, while nothing happened to the battery on the other slot. I have tested the "bad" battery on both slots - but it will not charge.
2. THE OTHER PROBLEM:
Next problem is that none of the batteries will get any power to the camera! This gives me two questions: is there something wrong with the connectors on the camera? Or are there any problems with the connectors on the batteries?
Nothing happens when I try to manually push the batteries with my hands.
I have tested to supply the camera with the chargers output while the (good) battery is on the camera - then disconnecting the charger to see if the camera stills gets power... Not working. The purpose of this was to see if the battery was unably to supply the startup, but would be able to "keep the camera alive". But, as said - no.
Any suggestions? I've looked into the "TOP MENU" and "Batteries" but really don't understand what to do there... First "Battery 1" on the menu gives information about status for former batteries. The second "Battery 2" on the menu is set to auto - and then there are "Segment 7" to "Segment 1" showing values from 17,0V to 11,0V.
The batteries are very well built, has a professional rubbery surface and looks fine in every way.
Any suggestions?
