It looks like I will need to pick up some V mount batteries to run my intellytech TC-160 light mat and a similar Falcon Eyes RX-24TD light. So far I've managed to avoid going the V mount route and have Sony L batts and the EX-1 type batteries in 60WH and 90Wh versions but even with a V mount adapter I can't get those to power my Falcon Eyes . Not sure what the problem is there frankly and I need to do a little more testing. Haven't been able to make it work with a D tap from the batt to the light yet either. When I try a dual L battery to V Mt adapter the draw from the light is so large that the L batteries shut down apparently due to a protection circuit. Put them on a charger for a second and they are fully back at full charge till I try them on the RX24 again.
I should get invested in V mounts anyway for use with FS7 and XDCA back so maybe this is just forcing my hand.
Do you guys have any advice for less expensive but reliable V mount batteries and charger. Also do you need a special battery rated for high discharge rates? These LED mats supposedly draw around 150W.
Thanks for any help
Lenny
Thanks for any help
Lenny
