Dan_The_Man
Hi there,
I was wondering if it was possible to combine two seperate shots in one frame. I want to film one shot and speed it up then film another shot at normal speed (both from exactly the same angle) and put them together so you cant see that they are two seperate shots on the screen at the same time. It's quite hard to explain so I have drawn a diagram: http://yfrog.com/5j65482106j
In this example I have a man running up to kick a chair. When he kicks the chair it will go flying off in slow motion without changing the speed of the man. To achieve this I would need to cut together two different shots, the one of the man running at 100% speed with the shot of the chair falling at 50% speed - how do I get both these different shots in the same frame?
I have posted this in the After Effects forum but am not sure if this would be the best program to do this with.
Any advice would be much appreciated.
