I am considering buying a power station to run an Aputure 120D II light instead of a V-mount battery?
Any advise regarding this route?
How do I know which power station to buy?
- pure sine wave
- 150 Wh
- AC output 100 Watts continuous
Does it matter if I use a power station that only outputs 110 AC when it is plugged in Australia that uses 240volts? Will this cause issues with flickering, sync issues with lighting with other lights?
If its AC output is 100 watts continuous, what would happen if I put the 120D on full power as it uses 120 watts, will that damage anything or just shut off?
Does anyone know which lasts longer or has grater recharge cycles, V-mount batteries or Power Stations?
Here is an example of the options - https://www.ebay.com.au/itm/S270-S1...hash=item41f4eca7fc:m:m8p153sTU4dsA6iwE1G1Czg
This only outputs 110 volts AC.
Thank you.
- pure sine wave
- 150 Wh
Thank you.
