Using Mix Out of SD302 for com devices
timapter
Hey all,
I need to get a cable made up for my SD302 that will allow it to sent a mic level signal into a Sony UWP-C1 transmitter. I want to use it as a pseudo-comtek for the drama I start on monday. We'll have three receivers that will be able to tune to that frequency..
I want to use the mix out (Ta3), and go into the sony which is on a minijack. Problem is that the mix out level is a hot signal ("fixed at its -15dBu nominal level" according to manual) and the sony only accepts mic level signals (because its crap).
What cable could I get made that would allow this interface to work? Im thinking a ta3f to dual minijacks (left and right - then I can choose which channel to send on coms, i dont want phasing and the Sony is obviously only mono)? Bit of an emergency this one, replies most welcome - Im an electrical idiot, so instructions I could give to the local cable man would be handy.
Cheers
You could pad down the signal with some resisters if your solder skills are good. Or you might try splitting the headphone jack and just running the sony off that. If this is just for political monitoring then any signal should do.
Cheers
hmmm. not a bad idea, but ill still need to pad it down. its so stupid that the sony's only like mic levels. Ill have to give this guy a call on monday and try find a solution.
Tim,
When I use my ListenTech's, I split the headphone and send one to the LT. It works great for me. I'm not sure you'd have to pad it down when going through the headphone jack...give it a try.
GL on the new project. My project for tomorrow cancelled due to SAG problems.
New customer so I'm not charging a cancellation - another low-budget project. ;-)
Phil
Ha! Wicked thanks Oleg... and phil Ill also give that a try just now. the Sony is a crummy thing so I cant imagine it liking the headphones out.
Where did you get your listentechs phil? im interested...
I got them through Trew - I really don't use Coffey any more because they are in California, so I would have to pay sales tax and shipping from them, whereas I only pay shipping with Trew. They were drop-shipped by ListenTech, so they only took a couple of days to get to me via UPS ground. Not sure if UPS ground can make it all the way to SA. ;-) I don't think their trucks float.
Phil
