Using Log and Transfer- Clips not loading
brownhood
Using a MacbookPro, FCP 6.05, FS-160 - I "organize P2" on the Fs100, connect it to the computer, via dd drive on the fs100, copy the "contents" and Lastclip..." to own folder on external HD (using FW800 Gtech)... I open log and transfer and click on "use custom path" and select the folder where info/clips are located. Nothing happens.... the clips should load into the log and transfer clip spots but nothing happens... I have tried this with other folders i have clip info from the fs100 or P2 card.... I'm sure I'm doing this correctly because it has worked before but for some reason is not working now. It worked 3 days ago on a folder with info/clips...... the same folder is not working now...
Has anyone experienced this intermitten problem with log and transfer?
Chris
