The guide (classroom in a book) says "the clone stamp tool samples the pixels on a source layer and applies the sampled pixels to a target layer; the target lay can be the SAME LAYER or a different layer in the same composition". Then it goes on to show you how to do this using a different layer (later on in the footage). I have a static scene with a crew member in the reflection of a large glass window. I don't have a shot without the crew member in the shot, so how do I use the clone stamp tool to remove her using the SAME LAYER? The guide doesn't say much on how to use the tool.
More details about the footage:
I have crew member's reflection in a large window in the background. The shot is static (camera does not move), but she does just a bit (she moves her arm).
The reflection is translucent; you can see everything outside, but the reflection takes precedence.
Would the History Brush Tool be a better solution?
Any thoughts?
Thank you!
Thank you for your help!
Any thoughts?
Thank you!
