THoff said:You want manual lenses for use with any of the 35mm adapters. Lenses designed for digital cameras rely on signals from the camera, which will be absent with a 35mm adapter.
Christopher Barry said:You need to maintain your camera at the optimal level, say on HVX around F2.8. Compensating the HVX iris will not avoid overexposing the Brevis diffuser/ground glass, resulting in overexposure and/or burned out highlights.
Abaddon said:So in other words, the EOS lenses aren't really the way to go.
I was hoping to get them because I shoot stills with the Canon, but better to save myself the headache I guess.
Andreas said:Exept that you need a minute or two for adjusting the desired aperture, Canon EOS lenses are a great way to go, specialy if your still camera is Canon and even more if you alwready own a few like I do. Nikon are great also.
best
Andreas
THoff said:Regarding the overexposing issue, there is really no question about what is happening.
The GG / diffuser is the equivalent of a projection screen, and if it is overexposed, you can't film the projection screen with a ND filter or a smaller aperture and get a correctly exposed, detailed version of what was projected -- all you'll get is a dark, featureless mess.
