Matt Grunau
Adobe Demigod
Hi all. I recently had a wonderfull shoot of a local high school perfoming a musical. The sound is great. There are places where there is only one singer, and only a few instruments accompaning. And there are places with the full band and full cast singing.
The entire play was piped into the DVX at Line out of the mixing board. I have applied a Track Compression plug with 3:1 compression starting at -18 db. The effect is great. Everything is brighter and much louder where needed, and things balance wonderfully. But, when there is a louder section with the full band and many singers, the dbs can go as high as +4. I want to maintain the sound quality and leveling/boost the compressor brings, but I obviously cant clip that high.
If I use a simply volume envelope to decrease the louder parts will this affect the job the compressor is doing and potentially negate its great effect on the overall audio? Or, is there a way (and should I) to keframe the Master Audio just for those parts?
Lastly, I play on doing a surround mix of the whole thing using the back channels either with a light reverb, or a stero expander (or both) which from initial tests sounds great. I want to export as an AC3 and I know that I can disable the post processing Compression>Film presets to keep it as loud as I want it. I also saw there were Music options under the same post processing options. Since this is a musical, and there is not a lot of dynamic range, would the Musical filter be ok? Or what would be a good settings for AC3 output to give me the best results?
Rather large post, so thanks for any help. I REALLY want this to come out great. This has the potential to be a fantastic work and allow me to give something back to the students who worked so hard. The actual shoot was a day they came back in SPECIFICALLY for the video, so we could have better lighting, proper camera placement, and no crowds/heads on camera. All the makeup, and 2+ hours of on stage time (to say nothing of other preperation), and the band showed up also ( unpaid for the few profrssionals who were) and only for a video shoot. These kids really did a hell of a job. I want my work to give them that back.
THanks again.
THanks again.
