using a tobaco filter, or other filters in camera
johney5
Hi all,
I'm about to shoot a new project, and am considering filtering in camera. Alot of you might go...why? Why not just use magic bullit? Like in cinema, sometimes taking a point of view before you start filming, gives you better results. I'm thinking about using a tobaco colored filter. I'm shooting in an tropical garden, and I want to lose some color, and dull the greens. Anyone have any comments? And, I assume I have to do white balance before I filter?
thanks for any imput.
Sounds like you made up your mind and know what you are doing. Go for it. You probably should white balance, but if you're going for a tobacco filter in a tropical garden , who knows, its already going to be heavily stylized, you can probably just use the daylight preset. Its really up to how you want it to look.
Me? I have found that I can do more in post with clean video. But it takes a certain eye while shooting to imagine what you have... it's almost like shooting for black and white, you have to look at everything in terms of tonal contrast first and foremost. Also, it does add time in post.
So it's up to you!
to be honest, it's a hard call...filtering is a pain..loss of light..on the other hand the image you are watching on your monitor often looks better. Years ago, when I started directing, a very good video clip producer told me that bringing an image closer to where you want to go, from the very beginning of a shoot, is better. I have always followed this logic, as opposed to younger DOPs who often shoot for the widest range possible..figuring that the final result will happen in post. Now in our digital age, it's a harder call. I'm curious if there are people out there who can give me technical reasons why filtering in camera is better, or worse than not.
I always try to achieve what I want as close as possible at the "prise de vue" when I shoot.
I don't think painting in-camera in HD or SD locks you up as much as diffusion in-camera does. I carry color grads, pols and NDs - otherwise nothing goes in front of the lens in HD. No cons, nets or mists in the kit. Nets should be, in my experience, rear-mounted for HD.
I say go for it. If you're close to 3200 or 5600K values prior to filtering, I'd opt for preset white balance settings over manual balancing. I think you'll have more consistent results once you start stacking glass.
Good luck, post some grabs.
P.S., I'll be in Paris again in less than six weeks. Can't wait.
e
