Using a spider dolly outdoors?
Grug
Hi guys,
I'm wondering if anyone's ever shot with a spider dolly outdoors over uneven terrain, and if so how you setup your track?
Would running the standard spider dolly flextrack over long planks of wood provide the level grounding you'd need for smooth moves? Or would conventionally leveled metal/PVC straight track be necessary instead?
Any thoughts or suggestions would be much appreciated.
Cheers
Flextrack is hard enough to use on flat ground. You're better off with metal track, apples, and wedges.
