octoberdeath
Is editing in FCP using a USB external hard drive ok to do? Is USB 2.0 fast enough I guess is my question?
krestofre said:It works, but firewire is preferred. The reason is that USB 2's speeds are burst speeds which means it fluxuates during use. Firewire is a sustained speed meaning you always have that pipeline open.
powerdog said:You want to record directly to your mac from the camera? I know they're working on a DV Rack equivalent for Mac, but that's the only option I know. And I don't remember if DVR works with Intel macs.
octoberdeath said:I don't really understand what your saying... but what I want to do is connect my camera to an external hard drive using the firewire port, then have my hard drive connected to my Macbook Pro using its firewire port. What I want to know is, will that work well enough for me so that I may edit on the road?
krestofre said:For DV footage it will work. It is preferable to add another Firewire port via that ExpressCard slot, but the daisy chain method will work.
krestofre said:He has a Macbook Pro, so PCMCIA solutions won't work. I don' think the express card FW800s are available yet, but I could be wrong.
But the point is that you can plug your camera into the extra firewire port on a hard drive and tell FCP to capture to the FW drive.
