URGENT: tsa lock reset on Lowepro roller X200
rawfa
Guys, does anyone know how to reset the tsa combination on the Lowepro roller X200 lock? I need this TODAY
I found this information, I hope it helps:
"The factory setting is 000.
1.) With the lock cable engaged, (setting 000) hold down the silver button located on the side of the lock, while rotating the numbers to the desired (new) setting.
2.) Release the silver button at the new lock setting.
3.) The lock is now set to the new setting. Be sure to note this 3-digit setting in case you forget."
Thanks, I actually sold the bag to someone and I could not remember the combination but I ended up remembering :)
Youtube would also save you, the TSA locks are fairly simple to pick and therefor to reset. You can buy a set of master keys on ebay, or make your own from plans on the web. Essentially different shape skeleton keys, not at all secure.
