URGENT: Lost sound on Mini-DV tape?!?
brandtb
:Drogar-BlackEye(DBGI had captured (via DVX100b) some footage from Panny AY-DVm63PQ tape successfully (vid/aud)...but decided I wanted to go back and capture some more. When started playback, prior to new capture, there was no audio signal (no signal on LCD's "meters" either). I tried it in another Panasonic camcorder and the same happened. I decided to try and record on end of that tape and vid AND aud was recorded...and played it back and got audio?!? I've used thousands of these tapes never a problem like this. This tape is part of a documentary - and the material on the tape is very important. I need some advice here quickly...I'm in a huge huge bind here. Thanks to all.
Did you playback that part that was captured successful on the camera? Is there sound? If there is sound then the error happened during shooting (somebody bumped the switch etc.) and there's nothing you can do, if there's no sound then that might be a camera issue.
