URGENT! Clips play at double speed in timeline
Spartacus
Ok,
I did everything like usual when streaming DV50 via a MBP to a G-Raid, HVX is set at DV50 so is FCP and so is the Sequence.
It records flawless, but when I put the recorded clip on the timeline it plays at around double speed without sound!
I opened the clip with the Quicktimeplayer - normal playback (well soft picture...)
I opened the clip with another MBP and FCP - normal playback
Both MBP have FCP 5.1.3. installed!
Please tell me that I just accidently altered a setting or sth, I need this setup tomorrow at 10!
Thanks!
Might be a sequence settings issue. Open the sequence and go to Sequence > Settings and make sure that all the settings match your footage.
First thing you should do when those things happen is to restart final cut. Sometimes lots of problemes can be solve that way!
