At the render, go to the custom tab and under audio choose what you desire. Uncompressed maybe, 320kbps if mp3, I need more details on what you're doing. You're problem is the quality of the audio - for the best option (when rendering video in MPEG) render audio separately @ .ac3 under the same title.
my problem is not quality, my problem is the volume level. Its a videoclip.
The sound of the video is a wav. If i compare the volume of the original wav and the video it self, than i can hear a difference in the volume level and the waves are differents. one is bigger and the other is smaller.
I think that my volume level is -10db after rendering.
I'm choosing Uncompressed PCM and tried Uncompressed IEEE
double check to make sure you didn't bump the track volume or master levels. assuming you've checked these, did you add any fx to the audio? if you're using eq or compression either one could affect your final levels.
