Upwards camera tracking
OK I'm primarily a stills guy moving into shooting my first short this summer, so bear with me here. :)
This is a movement I see a lot in movies/TV but haven't seen discussed much. Basically the camera tracks up a subject. e.g. if the subject is using a phone in the phone both, in a close up it tracks up vertically from the buttons of the phone to the subjects head/mouth talking.
I've seen the ability to do this on large dollies, but what is the best way to achieve this with currently available equipment on a low budget? Obviously tilting on a tripod would be the easiest but that would change the angle of the camera. I'd like the camera to remain straight on.
Nothing is going to beat a proper (chapman) dolly for this move. It's a move that seperate a the big from the little productions.
Poor people would use a crane/jib or a steadicam or gimbal
Each presents its own challenge.
I'd probably use my gimbal on my little jib.
You could get it with a small jib like Morgan says... you get what you pay for. Price will trade off for micro jitters, payload max, operability. Low weight is not always good....
If you use a 5D, a Zhiyun Crane 2 has built in focus pulling. That would give you the same, more freedom but taxing on arm strength.
Thank you guys!
One of my photography tripods has a center column that moves up and down. I guess that would work in a pinch with a camera/lens with good IS and a steady hand...?
Thank you guys!
Most unlikely- I have a really nice solid 1990s manfrotto (when they made actual tripods) and it doesn't do it
How about a regular slider positioned vertically clamped to some kind of support? Maybe even a pulley and counterbalance weight to make the camera neutral. There would be no arc from this and it should be cheap unless your camera is really big.
The slider pulley counter balance should work.
IMO you would buy a lot of grip to make it function - a small jib or suchlike might be a more versatile investment
