N Nick Nick Active member May 2, 2006 #1 im curious as to how would one up rez standard def to high def and what exactly that does. I use fcp 5.1.
G Gorilla King Well-known member May 3, 2006 #2 If you're talking about upconversion like on DVD players, I don't know that you CAN do that. at least not with good results. You can however output to a higher res from FCP and I believe you can do the same using compressor.
Fuboy Active member May 4, 2006 #3 There is a whole section written here http://manuals.info.apple.com/en/FCP5_HD_and_Broadcast_Formats.pdf
