Uprezzing to HDCAM from MiniDV
Ukon
Ukon
What framerate are you running your video at?
I would suggest using the Snell and Wilcox UKON for a 1:1 upconversion. I've done a few onlines with the UKON upconverting 23.98 and 29.97 to HD. I have also tried upconverting my projects in Final Cut by scaling the video. If you are not going for a film out this will probably be fine if you just need an HDCAM screener for festivals.
Does anyone know how the Snell and Wilcox system compares with upconverting via Teranex?
Teranex
Teranex
I haven't seen a lot of upconversions via the Teranex but if you are going from 23.98 --> (23.98 or 29.97) or 29.97 --> 29.97 they are comparable in quality from what I've seen. If you go from 60i --> 23.98 you would want the Teranex. The UKON can't handle the frame rate conversion like the Teranex can.
