Luke
Ok, this is what i did.
1.Captured my clips in vegas
2.Imported a clip into APpro1.5 timeline (used proper 24pa timeline).
3.Followed the Uprezzing tutorial provided by disjecta. http://www.pinelakefilms.com/uprez.html
4.After completing the final stage (rendering on time line) i exported the clip as microsoft DV AVI.
5.opened up vegas, put the exported clip from APpro1.5 on widescreen 24pa time line(played smooth as could be and was much much sharper than the origonal)
6.Rendered clip using mpeg 2 DVD A2 widescreen setting.
7.Placed in DVD A2 widescreen project. Played in preview window and was smooth.
I havn't burnt a DVD yet but is there a drawback to doing it this way. It seems like it should play smooth once on a DVD. The clip looked amazing after the process. Ive heard there is a way to do it with PNG files in vegas but disjectas process is so dang easy and the render time isn't all that bad. Also, I didn't really do this to get it to play properly on a widescreen TV, i did it mainly for the added sharpness, so i also put the imported clip from APpro 1.5 into a non widescreen timeline in vegas and it letter boxed the footage on the 4:3 preview window. Then i rendered as as mpeg 2 DVD a2 non widescreen. The reason i tried it this way as well is because 99% of the time it will be played on a 4:3 set and i wanted to make sure it would play the same on any DVD player.(if i render as widescreen and burn as widescreen i understand that the DVD player will automaticly letterbox but if the DVD player is not set up correctly, somtimes the image will be streached out.)
So what do you think? Any drawback to this. I know i could have captured and edited in APPro 1.5 but i injoy vegas so much more.
Luke
Luke
