Noiz2
Sound Ninja
That's what I want to know. Is the control on the R-44 enough for field mixing or not?
4ch -20 dBu line out.
Thanks again.
-20dBu? That is a weird number. The line out should be either -10dBV or +4 dBu. I don't have a converter handy but it looks like that would be a very low level for a line out.
Will it work as a mixer? I kind of doubt it. But that may also depend on what you are calling a mixer. Conventionally a mixer mixes and as far as I can tell the R-44 doesn't mix. You have four ins and four outs so you should be able to use the outs as "direct outs" and feed the four channels to something that can record four channels but there is no mixing going on. So if what you mean when you say mixer translates to four mic pres then yes. If you men act like an actual mixer then no.
So no mixing. No panning, to EQ, no routing and your outs are RCA jacks, not a good choice.
Also like the FR2 you have limited and hard to read at a glance meters. And it has really bad battery life.
