Gohanto
I just started with Audition in addition to Premiere for editing sound. The best way I've found it cutting in Premiere and then editing the wave files in Audition (the way the program seem designed to work). The problem I run into is that the audio can only be cut 1/30th of a second at a time when working with 30fps video. This is even true when I import audio recorded separately from the camera.
Is there anyway to adjust Premiere so that I can edit sound more closely?
Or is there another workflow option that makes this easier?
