Uncut Clips
tolakvoa
How do you uncut clips after you cut the clips and saved then if you open the file then you don't want then cut. Undo button no lonegr work because it is already saved. There is gotta be easy way to do this,.
Delete the end or beginning part of the cut clip, then grab the end of the other clip and pull it out to the original length.
