Umbrella / Softbox battle out
10s
I've been playing around with a Translucent Photo Umbrella, shooting a fresnel through it & comparing it to an ARRI/ Chimera of equal wattage. I found a way to hook the umbrella to the light with a little help from gaffers tape, and it seems to work pretty good. Beside the obvious side spill ( I could always use a bunch of black wrap and shape the spill back some more) the umbrella seems to accomplish just about the same as the Chimera at a fraction of the price. The subject results seem very comparable.
Has anyone also tried this and what results have you had?
Re: Umbrella / Softbox battle out
shoot thru is more directional and less falloff than a softbox esp with the baffles. check your shadows.
So a little spun in there should take care of the fall off and directionality?
the soft boxes we use have two baffles, and they're much greater distance from the lamp than on a reflector.  you could try it, but you're still prob gonna have a rather more directional source than a softbox. if you're looking to soften it more, shoot it thru an umbrella and THEN bounce it into a card. you'll loose a few stops but, you have a 10K HMI, right? ;D
