Robertofish
I am looking into purchasing potentially 3,000$ worth of LED or Battery Powered lights in one form or another I would just want a standard 4 point kit, hair light, fill, key, etc, what do you suggest I have looked at batteries4broadcast.com they have an excellent bi-color led with power consumption rated at 50 watts and batteries up to 190WH!!!!!!!!!!!!!!!!!!!! I also would like if possible to have the outlet powering option available in the battery powered lights just in case we are actually near an outlet, what do you suggest? They would need to be bright enough to light outside when it is dark for a night scene, for those of you who are about to suggest powering regular lights via a generator I looked into generators and even the Honda Inverter Series EU2000 Watt is way to loud for the boom mics I use since they are very sensitive there is no possible way that it would work, plus I really like the idea of powering everything via battery and not via fossil fuel, what do you think? It could be more then 4 lights if need be and also could be a little over 3,000$ as I understand that LED lights and battery powered lights do get quite expensive overall.
Thanks!
Thanks!
