Hi, I have some problems with my Aja kona Lhe. I work with tiff and tga sequnces at 720 25p and 1080 25p and with dvc pro hd (converted from mxf inside final cut)
The problems:
Final cut (5.1) only outputs new frames when i hit "pause" space. While playing it keeps the same frame from where i was in timeline until i stop. Then it show the new frame.
also in shake i play a clip in reeltime but when i switch to output throw aja it gets very stroby playback and everything feels slower.
In Kona Lhe controlpanel under the format tab i can only select 720p60 and it says on the primary that "used by mac desctop". If i go to the control tab and change the default format to kona output to something else in the list, then I can change formats but i will not get any picture so i guess it should be on mac desctop.
Cheers Joel.
Ok i keep on reading the manul....
The problems:
Cheers Joel.
