Try Version 4.52 and P2 Select not working
Bertholt4
Hello I tried the 4.52 TryVersion - downloaded it from canopus.com - but when I try to load my P2 files with p2 select I only get the wav.file into the bin? Also, there is no preset for dvcprohd - when starting a new project. But on the website they say the tryversion has full DVCproHD support??? Did I do anything wrong??
You should be using a 1280x1080i project, and for importing clips, you should use P2 Select (in the Capture menu). Using P2 Select will ensure all the related pieces are linked.
You aren't using AVC Intra, are you?
