Trouble getting colors right - Vegas Pro 8.0c
David W. Richardson
Chapelgrove Films
I'm working on the edit of a scene for the period short "The Silver Key", and I'm having trouble.
The scene takes place at a party -- nighttime in a large mansion. It's during the Civil War era, so lighting is supposedly by candles and oil lamps.
The raw footage is too bright -- it almost looks like daylight. So I want it darker and warmer in color.
If I use various combinations of brightness, contrast, contrast center, hue, luminance, saturation, and the various color effects (color balance, color curves, color corrector, color corrector (secondary)), I can achieve a decent overall look -- but the party dresses worn by the two leads (on dress green, the other blue) go to almost black.
I've tried using the color corrector (secondary) to single out each dress, isolate its color, and brighten it, with some success -- but not enough. There are several problems.
First, green and blue are too closely related as colors. It's hard to change one without changing the other, at least slightly.
Second, the carpet on the grand staircase in the room is green, as is the upholstery on a chair in the shot. These too wind up being affected by adjustments to the dress colors.
So it looks like if I want nice colors for the dresses, then I have to settle for an overly bright, underly warm overall room color. Unless anyone has some advice.
Anyone??? :)
Okay, here is the raw footage.....
...and here is my current best color corrected version...
It's getting there. This is what it WAS looking like...
The girl on the right's dress actually IS that color of blue. But I can't seem to get it to BE that color and still keep the rest of the room looking warm and candlelit.
I came up with a look that I think works. Use the regular Color Corrector-Reset to None
Use the following values:
Low: Angle 171.3 Magnitude 0.204
Mid: Angle 139.4 Magnitude 0.286
High: No change
Saturation: 0.694
Gain: 0.962
Gamma: 0.759
Offset: No change
I know this is probably not what you're after, but I thought I'd add a bit of drama with my quick grade.heh
Well buhce, I would like a bit of vignette around the edges, though not as dramatic as that.
El Director, I'm trying your settings now. Thanks guys!
El Director -- when burned to a DVD and played on my 32" LCD TV, it's a bit too dark and too saturated. But it's getting close! I'll play with the adjustments a bit and see what happens. THANKS!
