Trouble capturing from my AG-DVX100B to FCE
aramikvideo
Hi all. First, let me say that I use FCE 2 because that is what I can afford on my semi-pro. budget. Being married, I'm probably lucky I was able to get that. I have a 1.25Ghz Emac running Tiger and have boosted my RAM to a gig, the most it will support. The app is installed on the internal 80 Gig drive and the scratch disk is on my external 250 Gig firewire drive.
This is probably pretty lightweight for most of you power users but it has been more than adequate for me for the last few years as I only shoot mini DV. Other than the infamous power module problem that was covered under warranty, this system has done what i needed and done it pretty well.
A month to six weeks ago, I received a new Panasonic AG-DVX100B and was thrilled to say the least. I was excited to have a camera of this caliber. I recently shot my yearly corporate video and, yesterday, went ahead and attempted to capture the first footage.
I used the "Capture Now" option since it's a relatively simple project and everything seemed fine. Just over five minutes in, the image on the capture screen froze and didn't capture any further footage. Upon further attempts, it did the same thing at the same, exact location. Eventually, I cheated a bit and got past that point but it did the same thing minutes later. I even used a different camera (consumer grade) and it did the same thing. Among other things, I also used the internal drive as the scratch disk just to see if that would help but no luck. It's got to be the tape or the way the DVX recorded to the tape, don't you think?
It would take too long to tell all the things I tried to work around this but maybe someone could tell me what's wrong. Is it a timecode issue or is there a compatibility issue between the camera and the computer? Is the camera faulty or did i have something set incorectly when I shot the footage? Btw, I didn't use the 24fps modes as I'm pretty sure FCE does not support this. I shot using just the regular scene file or the fluo. for inside the hardware store to cope with the fluo. lighting. Any suggestions would be appreciated.
Sounds like a timecode break issue. When your capturing the footage does it say in the bottom of the capture screen "Locating time code break" This has happened to me tons of times, what tapes are you using? And you should use your consumer grade camera to capture all your footage too save the DVX heads.
Thanks for responding. I'm really thinking it's a timecode issue as well. I am using JVC DVM60ME tapes. Do you think professional grade tapes could help with the timecode issue, if that's the problem?
i just did an experiment that worked. I had captured the footage into iMovie and exported as a Quicktime file. I imported it this way into FCE. I don't like doing this because FCE has to constantly render the audio whenever you make a move so it isn't very viable. What i did was export the FCE footage (after rendering the audio) back to tape on my consumer camera. It worked . I tried exporting directly back out of iMovie yesterday and it didn't work. The conversion to a QT file may fix the problem.
I do agree with your comment about saving the heads of the DVX. My two consumer cameras do all of my rewinding, I can tell you that! That DVX is my baby. Working with a camera like that makes me file like I'm on a whole new level. i will keep it safely tucked away in it's hard case unless I'm actually taping with it.
Well, I tried to capture the footage that went through the QT conversion back into FCE and i got the timecode break message. i guess I'll just have to work with the QT import directly into FCE for now. The audio rendering is a pain but I have to get working on this video.
Still, if anyone has a suggestion I'm all ears. Thanks!
Do you have the cam daisy chained through the external HDD? FW seems to be a chatty protocol and I have experienced timecode breaks because of this.
Jason
My cam is connected to the Mac. The external drive is connected to the other firewire port.
I have a Final Cut 4 for Dummies book that I refer to. Of course there are differences but a lot of the material does apply to my FCE. It has been a big help. I found a segment about changing how FCP4 handles time code breaks in the User Preferences window. FCE does NOT have this pull down menu. I have a strange feeling that the enhanced control in FCP might help here.
