Tripod? Is this good?
Forget about anything with a 75mm bowl, most of those aren't rated for over 15 pounds.
Anything that can handle jib arms and is worth while as a tripod as well will run around 1500 on the low end.
However, if you want just something for the jib, Los Mandy makes a heavy duty tripod (no fluid head, just sticks) for their jib and it's only around 500. Look at portajib.com
I use it all the time and it'll hold a ton of weight.
