visualmind
Hi,
I am shooting on an EX1, and I have two tripods with the Manfrotto HDV501 and 501PL heads. Primarily, I do event photography. Often, I get the framing I want, and the subject starts to wander off. After the head has been sitting in a single position for a while, when I finally move it, no matter how hard I try, there is a little "jerk" getting it started going (usually with pan, not tilt). Once it is actually in motion, the movement is perfectly smooth.
The lock knobs are disengaged, and the pan and tilt tension knobs are both very close to MAX (if they aren't, it is hard for me to keep a consistent speed once with head is actually in motion). If the pan tension is at the lowest value, the jerkiness at the start isn't really an issue, but it is impossible to make a smooth move.
The issue occurs with both of my fluid heads (both of which are relatively new and unused).
Any suggestions for how to make smoother camera movements after the head has been sitting idle for several minutes?
Thanks!
Thanks!
