I've been looking at the Cobra Crane 1 Plus: http://www.cameracranes.us/cobracranes/crane1plus/index.html
I contacted the company, and they said the jib, plus a 5 lbs camera, plus counter-weight would come to 45 lbs. He said it would likely work on my Libec LS-38M even though the head is rated for only 17.6 lbs (the legs are rated for 98 lbs). He said he uses a head rated for 20 lbs without a problem and his customers all use heads that aren't rated at 45 lbs because those are too expensive. My concern was that the heavy weight might damage the fluid mechanism. Is that possible? Or will it just mean that the tilt springs won't work while the jib is mounted? Anyone know about this?
