Tricks & Tips
filmguy123
Just random stuff that you have learned over the years and found helpful. Could be big or small. Could be a shortcut, a way or organizing a file, a workflow, whatever. Could be something advanced. Could be something you wished you'd have known for years or months before you figured it out. Post it up here and share!!
Example:
(1)
When importing a ton of clips, say 100, I find it useful to put all of these clips in a folder, then to make a sequence with the same name as the folder. I drag the entire folder into the sequence, putting all the clips back to back. Then I can go through the timeline and use apple+V to cut sections out and bring them up a track to extract the good clips.
I use this for live event coverage or sports highlights, rather than watching 100 clips seperately, it is much faster to scrub through. I do not find this method effective when dealing with a "planned" shoot, where I would rather label/title the clips individually.
(2)
Bring a clip to the second track and overlap it over a clip on the first. Apply a transition to the end of the clip on track 2. This is like the old school A/B editing, and it is still easier for me to perfectly match/time transition effects in this way for some things, rather than try to remember it on a single track.
So post up anything! Whether you think its obvious or a neat trick, I'd love to hear how others save time, organize their workflow, or little tips/tricks/secrets/shortcuts!
when I have many tracks of video/audio, i shrink the timeline bar size to the smallest (which hides the thumbnails) and then..
go into the browser and put a color label on clips that are alike (all wide shots, all A-roll, etc)
Place alike clips on the same tracks (T1 = A roll, T2 = B-roll, T3 = graphics, etc.)
I like to customize the keyboard to make + and - zoom into and out of the timeline respectively. This is an Avid thing and once you have it you'll wonder how you ever cut without it... :)
Noah
Noah
Doesn't holding down CMD and hitting + and - do this by default...?
For quick keyboard adjustments of audio, I highlight my clip and press CONTROL - and CONTROL + for 1db adjustments...and Control-[ and Control-] for 3db adjustments.
Highlighting a clip and hitting Option then arrow left or right will move the clip one frame in either direction. Highlight the video or audio only and hit the up or down arrows and you can move the clip to different tracks.
Set the razor shortcut to the "/" button.
The razor shortcut is useful because it will cut the selected region or if none is selected, all regions.
OMG, thankyou! Question though, you said control twice. Was that a typo?
Build a stock footage reel in your main sequence then nest it into another sequence then drop on the TCG filter and walla you have burned in time-code for a client to pick clips from. I have used this many times and maybe everyone already used this technique but for those who haven't try it out the next time your selling stock footage oh and you can change the name from TCG to say your company name.. Kind of Cool...
Jim Kinsey
Jim Kinsey
Excellent tip! That is what I'm talking about! :) Thanks for sharing
Place your playhead over a clip and press X. it will place in/out points around that clip. Good for quick selecting for exporting a single clip.
