Hi, I have been making a lengthy interview piece for a nonprofit organization and run into a problem that I think is causing me to waste a lot of time...
I am transitioning many times between clips...
The first part (transition out) is a three-layered clip. There is one piece of video footage overlayed over another, and then above them is a LiveType title project.
This clip transitions into a Livetype project only (with animated background in livetype).
The project will then transition back to a new video clip, then back to a new livetype title project, several times.
In order for the transition to work, and not just for the two livetype projects to transition between each other and simply have the video files cut to black - I HAVE TO EXPORT EACH SECTION AS ITS OWN FULL .MOV FILE and then bring it back in as one layer and create the transitions.
This export time is enormous over the whole project. Do I need to be doing this?
I am thinking there must be a simple solution...
(by the way, my transition is a keyframed video filter, but I have the same problem with actual Final Cut transitions).
Thanks...
Thanks...
