I have done a search for these subjects on the forum, but have found nothing.
1. I have some stills at the begginning of the time line lasting about 4 seconds each. When I go to the transition tab, and choose one, I cannot drag and drop it to the event, it immediately turns into the "NO" symbol.
2. In Vegas, your suppposed to be able to nudge along the time line by doing a CTRL-Right Arrow, but when I do that, it goes to the END of the entire event, which is 38 minutes long. It also seems like a lot of these shortcuts are not working properly, probably because I have it in the "wrong mode" or a switch is not turned on?
3. Specifically, I am trying to show three still shots in a row, no sound, transitioning using soft flash between them, then leading into the first frame of a concert that fades in with sound and music if that info helps.
Thanks in advance if you can help, I did give it my best effort to look this up on my own....
